Taz2 Offline
#1 Posted : Sunday, 23 July 2006 5:05:49 AM(UTC)
Taz2
Probably one for you Mick.....My VT has an electric aerial along with a Eurovox CD, tape and AM/FM receiver. When I turn the radio on, the aerial extends fully. There is no aerial height adjuster on the sound system. What I want to know is, if I buy a Eurovox system as above, but with the electric aerial function on the fascia, will the aerial height be adjustable. Or is the aerial height adjustment run through the BCM?
In thrust we trust
#2 Posted : Sunday, 23 July 2006 9:20:58 AM(UTC)
from memory there are two types of electric aerial arrangements, manual and automatic.
manual aerials run with a toggle switch for up & down, you can stop theme wherever you like.
the auto arrangements have a relay inbuit or close by that sends the arei
#3 Posted : Monday, 24 July 2006 7:41:08 AM(UTC)
Bruce, you can add a set of up/down buttons anywhere in the car, and in conjunction with a VL-VS power antenna module, control the height yourself - without having to buy a eurovox system with the buttons.
If, however, you do want to put the radio with
Taz2 Offline
#4 Posted : Monday, 24 July 2006 4:41:32 PM(UTC)
Taz2
Thanks Mick....yeah I would appreciate the ciruit details.
The power antenna module is that small box up under the glovebox on a VN/P atleast I gather.
Bruce
In thrust we trust
#5 Posted : Monday, 24 July 2006 4:43:10 PM(UTC)
That's correct mate, grab it, and a section of loom that plugs into it, and I'll tell you what they all do, and how to wire it to your switches.
Which type of switch do you want to do? Head unit or seperate?
_____________________
