I have a V8 diff from a HQ ute and just wondering if the axles and centre bits will fit a sedan diff, what do I need to look for to find out which diff I have. When it comes to the diff housings are there any difference between the 6 cylinder and the 8 cylinder diffd.
Hi Fred.
Yes, the axles & diff internals are interchangable between passenger & commercial diffs in the HQ V8 Salisbury. You really need a diff guy to swap & set-up the crown wheel & pinion though.
The 6 cyl HQs (exc. 1 Tonner) use a banjo diff, not |
Hi Terry, I'll take it into Rockhampton as soon as I can track down a sedan v8 diff. Fred
