#1 Posted : Thursday, 27 July 2006 5:30:59 AM(UTC)
just wondering if a diff and diff housing with brakes and all from a hx sedan go into a hg/k/t??
#2 Posted : Thursday, 27 July 2006 6:57:08 AM(UTC)
Not easily as the HX is much wider than the K/T/G and has coil rear springs compared to leaf springs.
It can be done, but is nowhere near a bolt-in job for the home handyman...
Cheers...Dave
classic oz wreck Offline
#3 Posted : Thursday, 27 July 2006 6:58:09 AM(UTC)
classic oz wreck
not without major modifications...hq to wb sedan all had coil rears..hk ht hg ..leaf springs..track is also wider on hq on..
www.classicozwreck.com.au
#4 Posted : Thursday, 27 July 2006 7:08:19 AM(UTC)
Not even close. Brakes are the same though, just the stud pattern that the drums are drilled for is different and the wheel cylinder bore size may be different. If you want to modify a large salisbury from a later model to fit a HK-HG, go and measure up a
