jayHK69 Offline
#1 Posted : Sunday, 1 April 2007 5:57:08 AM(UTC)
jayHK69
my oil is badly contaminated with water (blown head gasket) how do i get the milky sludge out of the motor ? do i need to strip it down or is there another way ?
thanks
David Offline
#2 Posted : Sunday, 1 April 2007 8:43:37 AM(UTC)
David
Hi Mate,
I expect the experts will correct me if I'm wrong, but I would run it with flushing oil, drain and refill with normal oil.
David
#3 Posted : Sunday, 1 April 2007 7:34:47 PM(UTC)
have you fixed the head gasket?
even put cheap oil from Woolworths of coles and put a bottle of seal up in the eater. take the car for a 20-30 min drive to get it hot. get home drain the water and oil. i blown a head gasket in my VL and put seal up in it
#4 Posted : Sunday, 1 April 2007 10:49:23 PM(UTC)
Flush the motor out with diesel.
Drain the oil........ Put about 6/7 litres of diesel in.... take the coil lead out....crank it over for a while.......drain out diesel...change oil filter.... fit new head gasket....or two cans of chemi weld.... drive of
jayHK69 Offline
#5 Posted : Monday, 2 April 2007 4:08:39 AM(UTC)
jayHK69
thanks for the help every one
This page was generated in 0.158 seconds.
