VL05 Offline
#1 Posted : Saturday, 29 July 2006 8:35:34 AM(UTC)
VL05
Gday,talking V6's here. Just wondering if a manual VN gearbox will fit a VR. It's just I'm looking at doing a manual conversion to my VR and can only find manual VN's out there as donors.
Furthermore I asked an ebayer a few questions about a manual gearbox for sale and he said the VR V6 manual and auto engines are different? Is this true?
Many thanks in advance, Conor.
WANTED: GTS rims, seats and mirrors to suit HJ.
#2 Posted : Sunday, 30 July 2006 12:06:56 AM(UTC)
Hi Conor.
The VR auto V6 has an extra sensor on the cam, that the manual V6 doesnt have. The motors are otherwise mechanically the same. You will also need a VR V6 manual ECU & engine wiring harness & just ignore the extra sensor. If your VN donor car
#3 Posted : Sunday, 30 July 2006 12:06:56 AM(UTC)
Hi Conor.
The VR auto V6 has an extra sensor on the cam, that the manual V6 doesn't have. The motors are otherwise mechanically the same. You will also need a VR V6 manual ECU & engine wiring harness & just ignore the extra sensor. If your VN donor car
#4 Posted : Tuesday, 8 April 2008 4:35:10 AM(UTC)
hi ive got 94 vr commodore series 1 my gearbox wont change when i tramp it it wont change gears
#5 Posted : Saturday, 30 August 2008 3:20:00 AM(UTC)
Hi all,i have a VR commodore with a VN gearbox and am having trouble with the wiring harness and getting the speed sensor to work,can anyone please help me.
#6 Posted : Saturday, 30 August 2008 4:21:10 AM(UTC)
Best off running a VN computer, memcal & harness.
You'll never sort it out otherwise, unless you want to spend big $$ at an auto sparky, and more again on a Memcal re-map.
____________________________________________________________
#7 Posted : Saturday, 30 August 2008 4:21:10 AM(UTC)
Youll never sort it out otherwise, unless you want to spend big $$ at an auto sparky, and more again on a Memcal re-map.
_____________________________________________________________
#8 Posted : Sunday, 31 August 2008 2:43:51 AM(UTC)
im looking for a auto vr series 1 gearbox im having trouble looking for one
clubby677 Offline
#9 Posted : Friday, 5 September 2008 10:57:05 AM(UTC)
clubby677
The motors are different between auto and manual the crank is the difference so the answer to the question is no the manual want bolt up to a auto motor.
I do have a brand new crate motor (Long V6 series 1 for manual) if you are interested ?
He who di
He who dies with the most toys wins!
#10 Posted : Friday, 19 September 2008 3:52:47 AM(UTC)
If You Have A series 2 vn motor up to vr the manual gearbox should fit up. due to series 1 you cant put manual behind auto engine but series 2 you can as it sais in the gregory manual check it out
#11 Posted : Friday, 19 September 2008 11:22:12 PM(UTC)
You can bolt a 5 speed up to an early VN auto engine its just that the custom flywheel to suit costs ~$450 from CRS.
If at first you dont succeed then
#12 Posted : Friday, 19 September 2008 11:22:12 PM(UTC)
You can bolt a 5 speed up to an early VN auto engine it's just that the custom flywheel to suit costs ~$450 from CRS.
If at first you don't succeed th
#13 Posted : Tuesday, 30 September 2008 9:49:16 PM(UTC)
DOING CONVERSION VN AUTO TO MANUAL SERIES 1 CAN ANYBODY HELP ME WITH THE TAILSHAFT DRAMA IM HAVING MY AUTO YOKE DONT SEEM TO FIT THE MANUAL BOX AND IS THE LENGTH DIFFERENT IN THE AUTO TO MANUAL SEDAN NCAN PPL SAY MANUAL TAILSHAFT LITTLE BIT LONGER CAN I U
#14 Posted : Tuesday, 7 October 2008 11:24:48 AM(UTC)
you will need either a manual tail shaft or the front half from a wagon etc
#15 Posted : Saturday, 11 October 2008 2:23:33 AM(UTC)
whats the difference in manual to auto yoke and the tailshaft
#16 Posted : Tuesday, 21 October 2008 9:33:59 AM(UTC)
ok got my car going real good now after that auto to manual conversion anybody tell me the standard killowatts for v6 vn series 1 manaul cheers
#17 Posted : Sunday, 30 November 2008 8:02:46 AM(UTC)
none of yous now what you are talking about and auto to manual change is easy if you have a v6 series 1 it has a 6 bolt crank, to change from auto to manual you will 1 need to change the flywheel 2 have a manual tailshaft the auto is two long , change the
#18 Posted : Sunday, 30 November 2008 8:06:24 AM(UTC)
sorry i also left out that a vn v6 series 2 has a 8 bolt crank and that a series 1 is prone to brke at the crank so a series two is better, so if you take a box from a series 1 and want to install into a series 2 a different flywheel is needed a 8 bolt fl
#19 Posted : Sunday, 30 November 2008 8:08:22 AM(UTC)
sorry left some thing else out make sure when removing the gearbox you leave the speedo plug in the box the difference between auto to manual is auto has a small shaft and manual has a long shaft thats it nothing else good luck
#20 Posted : Thursday, 22 January 2009 1:22:54 AM(UTC)
i Blew my vr series 2 gearbox and all i can get is a vn series 1 box for it will it work
Guest (14)
This page was generated in 0.092 seconds.
