#1 Posted : Tuesday, 3 April 2007 6:06:16 AM(UTC)
Hi all
Have picked up a grey motor that hasn't been started for a couple of years.
I want to get it going, but before I fire it up is there anything I should?
ie take out spark plugs and add a bit of oil
what about the oil pump
any advice appreciated
thanks
#2 Posted : Tuesday, 3 April 2007 4:15:27 PM(UTC)
you could quirt some RP7 in each cyl,if its not seized it sould turn anyway,change the oil and plugs check the points the carby may require cleaning too.
