#1 Posted : Sunday, 6 August 2006 9:23:28 AM(UTC)
Hi all,
Does anyone know where I can get a heater hose for my HQ 308 with Air Cond. The hose I need is the Water Valve Inlet to Manifold Outlet P/N 2822624. It has a bend at the heater valve, then travels along the inside of the LHS rocker cover before bending in towards the carby, then a very sharp bend onto the inlet manifold. Unfortunately I have a pinhole size leak in it, just above the clamp at the manifold, so there is no room to cut and shorten it.
I have tried a few auto parts stores without luck.
Any info would be greatly appreciated.
Thanks. Gerard.
HQ - Jet Smooth
#2 Posted : Sunday, 6 August 2006 9:24:58 AM(UTC)
Sorry guys, I think I put this in the wrong section. Feel free to answer it though :-)
HQ - Jet Smooth
ozjason Offline
#3 Posted : Sunday, 6 August 2006 7:59:00 PM(UTC)
ozjason
Hi Gerard,
The last few times I've been to buy heater hose, I've been told that they no longer make pre-pressed/shaped heater hose for the old holdens, and you have to buy a cut length of straight hose, and just form the bend yourself. Seems to work o
#4 Posted : Tuesday, 8 August 2006 9:43:23 AM(UTC)
Thanks for the reply Jason.
I really wanted to avoid that method. The last bend as it goes onto the manifold is VERY sharp. I might have to get a hose with that bend and cut the other end to suit.
Cheers. Gerard.
HQ - Jet Smooth
This page was generated in 0.106 seconds.
