Hi all,
I originally put this post in buy/sell/swap by mistake, so i'm now righting my wrong!
Does anyone know where I can get a heater hose for my HQ 308 with Air Cond. The hose I need is the Water Valve Inlet to Manifold Outlet P/N 2822624. It has a bend at the heater valve, then travels along the inside of the LHS rocker cover before bending in towards the carby, then a very sharp bend onto the inlet manifold. Unfortunately I have a pinhole size leak in it, just above the clamp at the manifold, so there is no room to cut and shorten it.
I have tried a few auto parts stores without luck.
Any info would be greatly appreciated.
Thanks. Gerard.
HQ - Jet Smooth
Dr Terry has access to some of these hoses. |
Sorry guys....... I shouldn't read my own handwriting without my glasses on :-) The part number of the hose I'm after is 2822679, not the one listed above.
Thanks Byron for your advice. I have sent off an email to Dr Terry, hoping I can find the righ
