rust and grease Offline
#1 Posted : Tuesday, 8 August 2006 7:31:55 PM(UTC)
rust and grease
Further to previous posts about fitting HQ or Chevy wheels to Commodores or vice versa, my advice is don't even think about it... with or without adaptors. The slight difference in Pitch circle diameter is enough to cause excessive and dangerous strain on wheel lugs and hubs as well as "working" of the metal around the wheel bolt holes.
One query though...how critical is it to have a perfect match between the car's hub and wheel centre hole diameter, in other words is the wheels load borne mainly by the hub or the wheel studs or a combination of both??
#2 Posted : Tuesday, 8 August 2006 8:13:02 PM(UTC)
The weight is predominatly borne on the hub itself (spigot).
If your spigot bore is too large for the spigot, the additional strain breaks the wheel studs (common prob with guys fitting late model commodore rims with a 72mm spigot onto earlier ones wit
