#1 Posted : Tuesday, 8 August 2006 10:02:59 PM(UTC)
how do you go about geting a new electronic dizzy for a hq 186 red motor,what car do you get it for and were can you get one because i cant seem to find one anywhere,they seem to be all for v8s.
#2 Posted : Tuesday, 8 August 2006 10:19:36 PM(UTC)
Hi golden holden.
The dissy you need for any red motor 6, is the Bosch HEI unit out of a VC, VH or WB 6 cyl. The VK EFI 6 uses a similar unit again. You will also need the matching coil & also rewire the 12v supply to by-pass the ballast resistor.
D
#3 Posted : Friday, 11 August 2006 8:50:49 PM(UTC)
thanks dr terry ill check it out and go from there.
#4 Posted : Thursday, 1 March 2007 1:47:41 AM(UTC)
how do you rewire 12v supply to by pass the ballast resistor ? and what is a ballast resister ? cheers
#5 Posted : Thursday, 1 March 2007 2:50:40 AM(UTC)
In a Holden, the ballast resistor is the wire that runs from your ignition switch to your coil. A few inches from the actual ignition switch, it changes colour but, ATM, I can't remember what colour it is.
A ballast resistor (whether it is a wire or a
Edited by user Thursday, 1 March 2007 2:51:36 AM(UTC)  | Reason: Not specified
#6 Posted : Saturday, 3 March 2007 8:04:29 PM(UTC)
On a HQ Its a pink wire and it says resistance do not cut on it and it goes right in to the plug on the starter switch and it has a bigger pink wire going to the same connection and at the bulkhead end of the loom it joins to a yellow wire on the same ter
Edited by user Sunday, 4 March 2007 12:47:52 AM(UTC)  | Reason: Not specified
#7 Posted : Tuesday, 8 May 2007 2:01:40 AM(UTC)
i read this page the other day and thought it would be relevent on page one as someone was asking about ignition systems its from page 8 cheers
This page was generated in 0.100 seconds.
