#1 Posted : Sunday, 13 August 2006 6:30:56 PM(UTC)
need some info on how to determine the difference between a 351 and a 302 cleveland just by looking at it, and also determining what heads are on it, seller does not know, and i can only view photos via computer, thanks regards adam
Paul351xb Offline
#2 Posted : Sunday, 13 August 2006 7:29:41 PM(UTC)
Paul351xb
is the engine still in the original car? If not, you need to measure the stroke with a piece of wire down the spark plug hole.
#3 Posted : Sunday, 13 August 2006 8:59:54 PM(UTC)
thanks paul, no the engine is out of car, so the blocks are the same d block - square block, h block etc, but stroke is different ?, can you help with the length,
can the heads be determined 2v 4v etc without dismantling, cheers adam
Paul351xb Offline
#4 Posted : Monday, 14 August 2006 11:40:13 PM(UTC)
Paul351xb
Adam,
3" for 302 3.5" for 351.
4V heads have a much larger exhaust port than the 2V heads.
4V is pretty rare, and with the octane in todays fuel you would be better off with the 2Vs for street use.
