#1 Posted : Sunday, 20 August 2006 1:28:23 AM(UTC)
G'day again, can anyone tell me what the pulsator after the commy (VN) in-tank EFI fuel pump does and if it is needed if the pump is only feeding an external surge tank??
Can I just remove it and use a bit of fuel hose??
Thank's
life's to short not to be....
#2 Posted : Tuesday, 22 August 2006 4:23:40 AM(UTC)
Hi all, I've since found out why its there (to even out the fuel pulse/supply) but in my case the pump is just being used to feed a surge tank would I still need it? Both my units have bits of rubber missing from inside the pulsator so just thought instea
