DaMiEn Offline
#1 Posted : Monday, 21 August 2006 1:56:40 AM(UTC)
DaMiEn
hey guys i was juss wondering if anyone knows if they still sell
1).replacement hand break cables 4 hx 1 ton utes ???? and if so how much should i look at
2).if anyone knows a part number 4 the cone bearing on the 1 tonner axles and if the cone bearings are the same 4 sedan and tunner ??
because was worknig on the ute 2 day took the left rear wheel off to check how the pads where going saw them in great condition still got a bit off life so i was happy untill i put the tyre back on and went to tighten a wheel nut ad sheered it off it has been cracked 4 a while by the looks of it soo !! and i have the axles in the shed but
bearings are kaput
damo
#2 Posted : Monday, 21 August 2006 2:15:51 AM(UTC)
Damo try these guy's for cables,
www.autocables.com.au
Cheer's, Graham.
life's to short not to be....
DaMiEn Offline
#3 Posted : Monday, 21 August 2006 4:32:40 AM(UTC)
DaMiEn
thatkyou graham i didnt expect them to cost sooo much but wen it comes to safty its worth it
#4 Posted : Monday, 21 August 2006 8:43:35 AM(UTC)
If its only a wheel stud you can buy new ones. you have to pull the axle you can leave the brakes on knock the old stud through and belt the new one in. You can buy new bearings they are different as they are heavy duty for the tonners and have to be pres
