#1 Posted : Monday, 21 August 2006 2:56:01 AM(UTC)
hey i just brought a hj with some work done to it but when it comes to diff's i dont know a great deal, just wondering if someone could help me out and tell me how to tell what kind of diff ive got? i wanna get a 9inch but like i said, i dont know how to tell them apart lol. would be appricated, thanks!
DaMiEn Offline
#2 Posted : Monday, 21 August 2006 4:07:56 AM(UTC)
DaMiEn
ok the 2 difs they came out with where salisbry and banjo ok to dind out which is which go to the rear of the car with your flash light get down and have a look id u can c a bunch of bolts going round the outside of the diff houseing u will most probally
#3 Posted : Monday, 21 August 2006 5:45:21 AM(UTC)
thanks for the reply, yeah its got the bolts at the front, its got a crome housing aswell, thats why i wasnt too sure if its been changed to a 9inch. how can you tell the difference to a 9inch? thanks
#4 Posted : Monday, 21 August 2006 6:00:37 AM(UTC)
bolts are around the housing when lookin from the rear of the car that is, so its not a banjo.
DaMiEn Offline
#5 Posted : Monday, 21 August 2006 6:16:19 AM(UTC)
DaMiEn
no its most likley a salisbry the crome cover plate is a byeable accessory like rocker covers ect ect
and if u want to find the ratio the easiest way is to jack it up drain the oil pull off the cover and move the gears aound and on the gear thet is pare
#6 Posted : Monday, 21 August 2006 6:29:03 AM(UTC)
thanks, yeah i gathered... it makes sense now, salsibury 10bolt... haha thanks for ya help. now what do you reckon i should look into with the 9inch? i had a look into gettin a detriot locker but maybe just a bit out of my price. the guy i brought my van
peter_flane Offline
#7 Posted : Monday, 21 August 2006 6:33:03 AM(UTC)
peter_flane
Or jack up the back of the car until both wheels are off the ground. Chock the front wheels and put car in neutral with the handbrake off. Jackstands of course.
Then lay under the tailshaft and put a texta mark at exactly the bottom of it. Then get som
#8 Posted : Monday, 21 August 2006 6:11:20 PM(UTC)
Assuming that its got the original crown/pinion the ratio should be stamped on the pinion collar too.
The Yeti Offline
#9 Posted : Tuesday, 22 August 2006 12:12:37 AM(UTC)
The Yeti
Theres nothing wrong wit ha salsbury Yiggles, are you chasing a 9in for a reason? or just casue your mates recon there the best? if its just to sound tuff save your $$$$ the salsibury will stand up to a lot of ****
Macquarie Towns Hot Rod Clubs new website http://www.hotrodclub.info
See The Yeti's Chev build at
http://www.ozrodders.com...rd/viewtopic.php?t=17919
DaMiEn Offline
#10 Posted : Tuesday, 22 August 2006 4:06:39 AM(UTC)
DaMiEn
i must admite the the i thought bout the whole 9 inch thing but really is u can get tunna axles 4 the salisbry u have sumthink that will take a hell of a beating and could possably take out some of the weaker 9 inches
peter_flane Offline
#11 Posted : Tuesday, 22 August 2006 7:03:48 AM(UTC)
peter_flane
