#1 Posted : Monday, 21 August 2006 7:06:47 AM(UTC)
Hi all, I have wb one tonner and a 47 chev pick up cab I intend to gel both has anyone done the same or would know what modifing is invovled to do this
obsessed Offline
#2 Posted : Monday, 21 August 2006 9:14:04 AM(UTC)
obsessed
Hi guys im also building the same model chev and would appreciate any advice. I cant decide what chassis to use original with grafted holden front or hq-wb ute or tonner or for something different a 1960 pontiac sedan chassis.
#3 Posted : Monday, 21 August 2006 7:32:05 PM(UTC)
I'd use a late HX, HZ or WB tonner chassis with RTS (or ute/van if slightly shorter is required). Just make sure you check carefully for cracks first. The only problem is ADR27A compliance. If you're not worried about handling use a HQ or HJ chassis and y
#4 Posted : Monday, 11 September 2006 6:26:03 AM(UTC)
Just done this with a 48 pick up.
Tilt front
350 th350
WB ute chassis
Had to chop the middle out of the chassis and replace with straight rails. Added body mounts.
How do I post pics?
Later
Tom
obsessed Offline
#5 Posted : Tuesday, 12 September 2006 3:18:36 AM(UTC)
obsessed
I would love to see some pics. would be great if you had some of the completed chassis less body.
obsessed.
