joelm Offline
#1 Posted : Monday, 28 August 2006 3:21:07 AM(UTC)
joelm
hi all,
currently getting Grey motor rebuilt as follows:
mild grind, alloy timing gear, twin rebuilt 1 1/32 strommies & extractors, rebuilt head(port & polish, hardened inserts etc), but otherwise stock.
Also getting the 3 speed crash box rebuilt.
how long should the run in period be for these? will there be any additional time cause the gearbox is done at same time?
Thanks in advance.
ozjason Offline
#2 Posted : Monday, 28 August 2006 4:43:27 AM(UTC)
ozjason
Hi Joel,
The thinking seems to have changed these days... people don't usually recommend a particular period of driving carefully, or "granny'ing" an engine for the first little while. What they suggest is that you drive the car fairly normally. Don
#3 Posted : Monday, 28 August 2006 5:48:19 AM(UTC)
You should never labour a new motor the bearings really suffer. The recommendations I have used are to drive in normal city traffic but don't let it idle too long, such as traffic jams as this can cause the cylinders to glaze. The idea is to subject the m
ozjason Offline
#4 Posted : Monday, 28 August 2006 7:12:27 AM(UTC)
ozjason
John - interesting. My engine builder specifically told me the first drive had to have significant low rev labouring - said it was particularly important. Yet a quick google confirms what you say.
Well there you go - shows why it's important to liste
#5 Posted : Monday, 28 August 2006 8:58:53 AM(UTC)
Yes it's always interesting to take on board what people say and apply your own analysis.
But even with a well run in motor it is never wise to labour it, like a lot of people never get out of top gear and wonder why the clutch and drive train and motor
