hi all,was wondering what kind of power steering set up i need to use for my hq 1 tonner?it is fitted with a 350 chev,can i use a power steer unit that fit's a hq-wb?can someone tell me the exact parts i need to get to make this happen. cheers guys
Hi Grant.
Unless you can hold of the all parts from an HQ 350 Statesman, you will have to do a bit of work.
The normal HQ to WB steering box is the one to use, but the p/st pump, pulley & brackets etc need to be off a Chev motor. Also because the Ch |
cheers dr terry,will see what i can find.
Sorry to hijack your forum Grant, but Dr Terry, i was wondering if you got my e-mail the other day regarding the HQ coupe i have and the TAGS information i was enquiring about.
Hi Darrion36.
No, I haven't, sorry.
Which e-mail address did you you use?
Dr Terry. |
