#1 Posted : Saturday, 2 September 2006 6:15:18 AM(UTC)
hi, just wondering what is the best way to go about putting a 308 into a fj holden ute 4 speed gearbox,whats the best diff brakes front end, everything. what needs to be cut/welded to make it fit. thanks
The Yeti Offline
#2 Posted : Tuesday, 5 September 2006 10:51:52 PM(UTC)
The Yeti
the simplest way (not nessaseraly the best) is to get the kit form CRS
Macquarie Towns Hot Rod Clubs new website http://www.hotrodclub.info
See The Yeti's Chev build at
http://www.ozrodders.com...rd/viewtopic.php?t=17919
#3 Posted : Wednesday, 6 September 2006 4:25:17 AM(UTC)
HR front end and diff, add two leaves to the rear leaf packs or tramp rods if your making serious power.
If your doing a complete restoration you may want to make the tunnel higher and wider.
Also you'll need a bigger radiator with thermos.
Cheer
#4 Posted : Wednesday, 6 September 2006 8:47:15 AM(UTC)
In NSW stay below 300 cubes IIRC.
CherryBomb Offline
#5 Posted : Tuesday, 12 September 2006 1:12:55 AM(UTC)
CherryBomb
FIRSTLY, run this by your states RTA. And get the basic guidlines as to what is the Max allowed cid to body(factory) weight. you will be restricted to as how far you can go.
Secondly, look for a acredited engineer that is willing to see the project throu
Never stop being inspired,
