#1 Posted : Sunday, 10 September 2006 7:05:12 AM(UTC)
Yep got these chassis left over, not bent or rusted, have had advertised in local trading post to no avail. $50 each, I also have a stainless steel tray frame for a one tonner, needs new timber or alloy floor. $400.
By the way, will take a slab of vb for exchange for either chassis, if I can shift by the end of next week theyre going to scrap metal (along with the mint yellow WB panel van shell for the interest of memeber vl05.)
Also got hz RADIATOR SHROUD, Hz clutch fan, std fan, wb washer bottle less motor, good 253 short motor no heads has been reco but done a few ks, can still see hone marks want $400 but will take $300 this week to shift! for vl05 info the motor is a 253 red motor out of a hq-hz, not out of a mint yellow wb panel van(pretty cheap motor considering the same work to a standard eng block will cost you $1600)
Also can help out with stato parts, disk brake diff, doors, boot etc, or whole stato for a grand has 308 turbo 400.
Mr Void Offline
#2 Posted : Sunday, 10 September 2006 9:45:54 PM(UTC)
Mr Void
mate, where are you/the parts??
___________________
Why are you reading this, you should be looking up there^^
___________________
Rockett Offline
#3 Posted : Monday, 11 September 2006 7:09:04 AM(UTC)
Rockett
Hey mate,
Got a L/H manifold stove for a V8 HQ by chance????
Rockett
#4 Posted : Monday, 11 September 2006 8:24:37 AM(UTC)
Hi rockett, yep I got the stove and some manifold bolts and lock plates for you! Will bring them over next visit, pretty soon. One tonner finished and registered, will send you a photo, still a few bugs need ironing out though! jas
Oh for Mr void part
#5 Posted : Friday, 15 September 2006 7:22:43 PM(UTC)
chop chop next week, all going cheap $20 per chassis, shame to cut up must go. Located maylands perth, you want em reply in this forum
