#1 Posted : Thursday, 19 April 2007 3:05:13 AM(UTC)
Hey guys , when i picked up my landau shell it had new munroe shocks in the front.Now im debating pulling them out and putting a set of koni (d) adjustable .I have no idea how to set them up ,they are second hand but in good nick. Now are they better choice? and also with the muroes being new what is the best way to store them when they are removed? The front end is all neoprane (if thats how its spelt) and has heavy duty springs i also have a 2 inch round plate that has been set up to fit under the top shock brace .So any input and ideas on setting up konis,thanks chris...
#2 Posted : Thursday, 19 April 2007 9:46:14 AM(UTC)
Older koni's were adjusted by pushing the shaft right down until it bottomed out. You then turned the shaft clockwise for stiffer or anti-clockwise for a softer setting.
I believe that you start in the middle, fit them & go from there.
This page was generated in 0.098 seconds.
