YetAnotherForum.NET Help
#1 Posted : Friday, 15 September 2006 2:00:27 AM(UTC)
Can someone please advise how I can tell the difference between a Turbo pattern 308 block and a Trimatic pattern. I have been told that the top two bolts are the difference. If so can someone advise of the spacing difference between the two.
JBM Offline
#2 Posted : Friday, 15 September 2006 2:12:01 AM(UTC)
JBM
http://www.fastlane.com....earchTerms=turbo,pattern
This will help.
Edited by user Friday, 15 September 2006 2:12:55 AM(UTC)  | Reason: Not specified
#3 Posted : Friday, 15 September 2006 8:54:10 PM(UTC)
All 6 x bolts are in a different location, and the dowels are bigger and in a different spot for the TH pattern drilled block. HJ onwards blocks are identical though for both TH and 4-speed patterns, but they are just drilled differently. That is why the
This page was generated in 0.121 seconds.
