Fastlane
Holden Forums
Holden General Discussion
Trimatic/Turbo Pattern, How to tell the difference
Can someone please advise how I can tell the difference between a Turbo pattern 308 block and a Trimatic pattern. I have been told that the top two bolts are the difference. If so can someone advise of the spacing difference between the two.
http://www.fastlane.com....earchTerms=turbo,patternThis will help.
You only have to be in front at the end of the race. Edited by user Friday, 15 September 2006 2:12:55 AM(UTC)
| Reason: Not specified |
You only have to be in front at the end of the race. |
All 6 x bolts are in a different location, and the dowels are bigger and in a different spot for the TH pattern drilled block. HJ onwards blocks are identical though for both TH and 4-speed patterns, but they are just drilled differently. That is why the |
Fastlane
Holden Forums
