#1 Posted : Sunday, 17 September 2006 4:31:13 AM(UTC)
I have a Series 111 VS 5.0 litre ute and would like to fit an electric radiator fan. I have heard of people fitting AU Falcon electric fans but was wondering if I could just fit the VS V6 electric fan assembly. Is the V6 one too long or can it be easily cut down? It looks like a straight bolt in arrangement as there are some bosses molded into the end tanks of the raditor. The fuse box under the bonnet has some power wires running to a relay holder marked LO FAN-TH. I was hoping to just get the rest of the wiring from the wreckers and just plug it in, but do I need to get the memcal changed? Anything else I need to consider? Thanks in advance.
#2 Posted : Wednesday, 29 November 2006 5:50:18 AM(UTC)
Dude, ditto I have the same vehicle and am fitting EL Falcon fans now. Have had to trim them a lot to fit in but am closing in on the project. All I need now is to work out the wiring which should be as simple as wiring a temp switch in series with the
