#1 Posted : Friday, 20 April 2007 2:03:11 AM(UTC)
I Have a VN series 1 300klm it runs great when cold but as it warms the Idle gets rough if it is started when hot it is worse .I have changed plugs, leads compresion is ok ,Im starting to think it has something to do with the lean Idle from the ECU ,all the sensor have been check and are ok .
Can anybody help me out with this issue
#2 Posted : Tuesday, 24 April 2007 6:08:21 AM(UTC)
have you tryed removing the throttle body and cleaning the iac(idle air control) (little ports in there and the sensor aswell)with a carby cleaner then reassmbling. it might run rough for a bit but it should come good. i have come accross this before and
#3 Posted : Tuesday, 24 April 2007 9:30:13 PM(UTC)
Thanks for the tip will give it a try tomorrow.
#4 Posted : Thursday, 26 April 2007 11:18:02 PM(UTC)
VN IDLE FIXED YIPPEEE ,Thanks Mick you fixed 1 of my faults to do with the idle. I cleaned the throtle body and replaced the O ring seals on the shaft .This helped but did not fix totaly.
I got stuck right into it and can now better list the symptoms for
