#1 Posted : Saturday, 21 April 2007 12:57:54 AM(UTC)
ForSale: YB Cosworth Engine Package
Reconditioned YB blue top Turbo Cylinder Head - Complete with 16 new bronze valve guides, new valve stem seals, std turbo cams and buckets, pulleys, welch plugs. The head has been fully stripped and cleaned.
Valve guides from Burtons UK and reconditioning
Fully Balanced Cosworth bottomend - Standard size crank journals and rods. All checked (crack tested etc) and for straightness
New CP Forged Pistons. 8.1 comp inc light weight gudgen pins
New Total Seal Gapless Piston Rings
Cosworth 205 Block - Bored to suit CP pistons. Ends have been closed and honed to std size. New aux shaft bearing and welch plugs.
New High Energy Pro Circuit gated sump 6ltr. - Inc custom pick-up and Oil drain feed from turbo.
New ARP Engine Stud and bolt kit - Head, Big ends, Rods, Flywheel
New King Tri metal bearings Std size to suit.
New Magencore KV85 Competition leads from UK
New Cosworth multi belt front engine pulley.
Garrett T3/4 Turbo Newly Highflowed and new bearing case, gaskets - Work done by Garrett NSW.
32mm Garrett External Wastgate - Good working order - Garrett advised
New Racing Clutch from Italia Spares QLD - Clamping Pressure = 3700 lbs
New Custom 9 bolt Flywheel
Genuine Cosworth oil pump with bore squirters
Inlet manifold inc Weber Marelli throttle body, Plenum, Fuel rail, std injectors, fuel regulator, TPS, sensors
Cosworth Dizzy
Aux shaft pulley
Timing belt tensioner.
Crank timing belt pulley inc end bolt
Gaskets/Seals - New YB Head gasket from Danny M (same as used on his track car),new Felpro sump gasket, new Inlet gasket,new termostate gasket, Front cam seals 'half moon' used but in good condition.
SELLING AS A PACKAGE @ $11,000, Located in Adelaide
Unfortunately it's time for me to abandon the Cosworth Cortina for a while as I'm heading back to uni and won't have the money or the time to complete it.
I bought this engine not quite two years ago for $12,000, it was a good buy then and even more so now
Everything is still as I got it except:
-I sold the exhaust manifold as I wasn't going to use it
-The cam cover has been stripped ready to be repainted
-The block has been Painted black
-The Crank has been installed
-The pistons have been put onto the rods
Can be sent anywhere at buyers expense and I'll even help out putting it together if you're in Adelaide :)... I just really want to see it running!
Any SERIOUSLY interested parties can either e-mail me or call me on my mobile, 0422 228 521
