#1 Posted : Saturday, 23 September 2006 6:00:20 AM(UTC)
is it worth putting a 70mm throttle body on a v8 for 200 bucks thansk guys get back to me
#2 Posted : Saturday, 23 September 2006 6:02:33 AM(UTC)
can you put any bigger on or that just 70mm just about the limit on a vr v8 motor
Mr Void Offline
#3 Posted : Sunday, 24 September 2006 7:20:43 PM(UTC)
Mr Void
From memory commsport used to sell them exchange for about $250. I don't think 200 is a huge bargain but it's not a rip off..
The std t/b is 65mm (from memory) so putting on a 70mm will give you better throttle response and more top end potential if y
___________________
#4 Posted : Tuesday, 26 September 2006 3:59:24 AM(UTC)
will i need to put a differnt throttle plate on or will the standard one be ok be
#5 Posted : Tuesday, 26 September 2006 9:55:14 PM(UTC)
If your talking about the butterfly, they should come with one to suit the 70mm rebore. 65mm plate in a 70mm bore won't work. If your talking about the acctuator plate over the body then it's a straight bolt up to the new one.
