basketcasebear Offline
#1 Posted : Monday, 23 April 2007 6:38:42 AM(UTC)
basketcasebear
hey y,all
have changed back door handle on xf, with new ones, now the problem I have is even with the new one, it does not move the little slide inside the door far enough to open?? the inner handle opens the door fine? but not the outer one,
does anyone know the solution to this? and or how to fix it?
thanks already
ptpro
DOH!!!
Paul351xb Offline
#2 Posted : Thursday, 26 April 2007 6:51:47 AM(UTC)
Paul351xb
On the XBs there is an adjustment on the main rod so that you can fine tune it to open. I think there is something similar on the XFs. If not you might have to bend the rod a little bit going from the door handle down to the main latch. Also make sure th
