#1 Posted : Tuesday, 24 April 2007 3:35:33 AM(UTC)
I've got water leaking into the panno from the top of the windscreen and dripping on my left leg. I've tried to find where it's getting in but so far no luck.
I've pulled out a small piece of the silicone on the inside where it's coming in and put a couple of small pieces of paper in, then hit the outside of the car with the air gun, hoping to blow out the paper when i hit the hole but no luck. I tried the gutter and around the chrome strip at the top of the windscreen.
What next? It drips in whether the car is moving or not.
Scott
#2 Posted : Tuesday, 24 April 2007 6:22:59 AM(UTC)
your windscreen needs re sealing , my van did the same in 3 places,silicon wont fix it properly needs to be done by a windscreen shop.
jabba Offline
#3 Posted : Tuesday, 24 April 2007 5:44:51 PM(UTC)
jabba
The windscreen shops do the opposite to what you did. Soapy water mix spread on outside top of screen, then airgun from inside and see where it bubbles.
j
