Jampher Offline
#1 Posted : Tuesday, 3 October 2006 9:33:38 AM(UTC)
Jampher
Just pick up my HZ ute ute it has (iam told) Mazda bucket seats but they are to low, someone tod me to just put some spacer under the seat where it is bolted down, Iam open to ideas. there is another concern they are only held down by three bolts pasanger side rear right and drivers side rear left, again open to Ideas.
Tanks in Advance
Moose
Moose
Moose
#2 Posted : Tuesday, 3 October 2006 4:11:43 PM(UTC)
put some HZ bucket seats in .
Mr Void Offline
#3 Posted : Tuesday, 3 October 2006 8:10:34 PM(UTC)
Mr Void
More info?
If they only have 3 bolts can't you just go buy two more and fit them.... or do the holes not line up? In that case you can just drill a hole, seal it against rust and stick a bolt with a nut on it in there.
I think spacers would be the
___________________
#4 Posted : Wednesday, 4 October 2006 12:08:39 AM(UTC)
Hey mate where are you from and What do you mean when you say you just picked your ute up? Because if you are trying to get it ready for a roadworthy I wouldnt go drilling holes and bolting them in. Im in vic and Im pretty sure you need an engineers certi
HZute-efi-VS5L Offline
#5 Posted : Wednesday, 4 October 2006 5:44:12 PM(UTC)
HZute-efi-VS5L
well said cocko us even here in SA its iligal to drill holes an remout different seats that dont bolt straight up to the floor holes already. as for spacers, forget it there is no way thats legal.
hope that helps
jason
www.stickthisdecals.com.au
Mr Void Offline
#6 Posted : Wednesday, 4 October 2006 6:44:20 PM(UTC)
Mr Void
*the penny drops*
Oh, it has to go for a rwc! I think I'm on the right page now...
Yeah you need an eng cert here in qld as well, I got one when I went from bench to buckets. The guy that did it just kneeled down, had a look to see what fixings were u
___________________
Jampher Offline
#7 Posted : Thursday, 5 October 2006 5:43:01 AM(UTC)
Jampher
live in perth and only bought the HZ a couple of weeks ago I was home for three days before I had to fly back to work (two weeks away)and I spent those three days driven it and have not lifted the carpet to see where and if the fourth hole was there.Looks
Moose
#8 Posted : Thursday, 5 October 2006 6:16:02 AM(UTC)
Try and find a WB ute/van or tonner (normally Kingswood utes have buckets) with factory buckets at a wreckers. Check that it is actually a 2 seater on the ADR plate. If the seats are stuffed, get the runners off them and stick them on a good pair of VK or
Jampher Offline
#9 Posted : Thursday, 5 October 2006 8:37:07 AM(UTC)
Jampher
Sunday times, Quokka and the wreckers here I come. again thank you all
Moose
Moose
#10 Posted : Thursday, 5 October 2006 10:38:16 AM(UTC)
Jampher, Try Aussie Wreck in Midvale. They have quite a bit of older Holden stock and are usually reasonably priced.
Cheers...Dave
Guest (10)
