#1 Posted : Tuesday, 3 October 2006 5:46:33 PM(UTC)
Goodaye I fitted a 202 red to a 3ton toyota dyna truck using a crs adapter bellhousing it runs a 202 red with a standard holden red pressure plate and a 8.5" toyota clutch plate the problem is that that clutch starts to slip when loaded and only lasts about 10000 klm
the reason is that it is to small I wanted to adapt a bigger flywheel to the red motor to be able to run say an 11 inch clutch does anyone know if any of the v8 flywheels will bolt without too much trouble to the red 6 crank i am set up to do some small engineering mods but i needed some flywheel that would take about 11 - 12 inch clutch
Thanks in Advance
666 Offline
#2 Posted : Tuesday, 3 October 2006 6:27:59 PM(UTC)
666
Pat,
Why not try a Heavy Duty Pressure Plate ?
Is the Toyota Clutch Plate the same thickness as a Holden Plate ? (as if its not this may simulate a worn out/slipping Plate)
666
666
#3 Posted : Wednesday, 4 October 2006 1:22:19 AM(UTC)
the 202/3.3 blue motor has a bigger clutch than a red and bolt straight up
#4 Posted : Thursday, 5 October 2006 6:32:59 AM(UTC)
Thanks for the replies ok on the blue clutch it is bigger 9.5" but still not big enough when the truck is loaded its gvm is around the 4tonne marh this is why i wanted some info a flywheel possibly v8 that i might be able to fit to the red crank without t
Guest (5)
