#1 Posted : Wednesday, 4 October 2006 8:57:51 PM(UTC)
I have put 308turbo350 into six cyld wb onetonner.The crossmember does not line up.Pls help
#2 Posted : Wednesday, 4 October 2006 9:21:26 PM(UTC)
Hi oneton.
You need an HZ or WB TH350 crossmember. TH350 crosmembers out of utes/vans & one-tonners are rare, so it's easier to get a sedan/wagon/Statesman one & shorten it.
#3 Posted : Wednesday, 4 October 2006 9:43:23 PM(UTC)
thanks 4 reply Dr Terry.how do u meen shorten,is the chassi differant widths?
#4 Posted : Wednesday, 4 October 2006 10:46:31 PM(UTC)
Hi oneton.
The chassis is a different design. The passenger cars chassis consists of 2 'C' channels, so the crossmember sits on the inside of them. The commercials are a full box chassis & the crossmember mounts off 2 lugs which are welded to the insid
classic oz wreck Offline
#5 Posted : Thursday, 5 October 2006 5:45:17 AM(UTC)
classic oz wreck
you need to cut each side to decrease the width and then drill holes in the ends of the crossmember at chassis and use a nut and bolt to secure it....
www.classicozwreck.com.au
#6 Posted : Thursday, 5 October 2006 6:01:25 AM(UTC)
Go looking at WB Statesmans from 1980 to somewhere mid model (late 1982 roughly). These all had TH350 boxes. Late HZ 308 autos as well. Just do what Greg says. If you have an arc welder tack the nuts onto the ends of the crossmember - makes it easier to g
This page was generated in 0.094 seconds.
