joelm Offline
#1 Posted : Thursday, 26 April 2007 4:05:13 AM(UTC)
joelm
hi all,
ive got 2 single barrel strommies (1 1/32 matched) on a 138 freshly rebuilt grey (mild cam, ported & polished, extractors) and want to know the best way to tune them in?
Is there a recommended proceedure?
ive tinkered a little trying to set the idle speeds identical and then adjust the idle mixture, but have had really limited success...
any suggestions or links to how to's would be greatly appreciated.
Thanks in advance.
#2 Posted : Monday, 30 April 2007 10:37:57 PM(UTC)
Try using motorcycle vacuum gauges
#3 Posted : Friday, 4 May 2007 10:02:06 AM(UTC)
Airfilters off, disconect the butterfly shafts where they join before you start then do the front carb first, do the rear to match so their idling well together [stick your head between and listen one in each ear]they will make a nice "slurping" sound equ
This page was generated in 0.095 seconds.
