basketcasebear Offline
#1 Posted : Sunday, 8 October 2006 9:49:53 AM(UTC)
basketcasebear
another dumb question re temperature,
gauge just barely seems to register temp...is this more likely instrument panel.?? or temp sender??
thanks already
ptpro
DOH!!!
#2 Posted : Sunday, 8 October 2006 10:14:05 AM(UTC)
It could be either. there are diferant resistance senders out there,which alter the gauges actual reading.You need to check the actual temp in the rad with a master gauge to see what temp it realy is, then use a less resitance sender than what you have t
