#1 Posted : Thursday, 12 October 2006 7:25:14 AM(UTC)
hey all, i was wondering if any1 knows of a place that does manifolds for an eb six cyl? i am mainly just trying to tidy up the engin bay.
and while im here does any1 know wether i can remove the distributer and swap it with coil pack? if so is it worth it? and would i have to do any major work to the block to fill the hole it came out of?
thanx to all.
#2 Posted : Thursday, 12 October 2006 7:29:43 AM(UTC)
what do you mean does manifolds? that could mean anything.
#3 Posted : Thursday, 12 October 2006 7:40:23 AM(UTC)
sorry i mean fabrecation ( bad spelling i know ) i was curious on costs and stuff
#4 Posted : Thursday, 12 October 2006 9:17:26 PM(UTC)
A common modification is to fit the broad band manifold setup from an EF onwards.
Don't change your distributor to coil packs. Ford did this with the EF then went back to a distributor with the EL. The other disadvantage of using coil packs is that y
#5 Posted : Friday, 13 October 2006 7:46:59 AM(UTC)
thanx jim so r all the manifolds the same after the EF? if not wat would beter suit mine and why ( just so i can get an understanding of wats going on )
and about the distributer its just so i could tidy up the engin bay ( that side is aufully crampe
#6 Posted : Friday, 13 October 2006 10:41:22 PM(UTC)
I believe that all inlet manifolds from EA-AU interchange i don't know whether a BA-BF one will fit although the setup does not look much different.
I think that there is discussion on this upgrade on Fordmods.com.
