#1 Posted : Monday, 16 October 2006 7:17:32 AM(UTC)
my brother has just bought a 96 el futra and it has a problem that im guessing is abs related here is the symtoms when first started and you drive off and then brake for the first few times the brake pedal pulsates like a worped disc but he has replaced the discs and the problem still happens but after a while the cheak abs light comes on and the car brakes normally we have cleaned the abs sensors aswell but problem still occurs and help wood be great
sly376 Offline
#2 Posted : Sunday, 22 October 2006 4:06:50 AM(UTC)
sly376
Hey buddy the best way to find your problem would be to throw a scanner on it & extract the codes out of the system, which basically means it will tell you where the fault is located. You can eather use a scanner on it or manualy extract fault codes, by m
