#1 Posted : Saturday, 28 April 2007 7:34:53 PM(UTC)
Hi, can someone tell me how you can run a vn EFI 308 in a HJ and still run factory air, the commodore compressor looks like it will hit the steering box, is there a way around this - such as aftermarket bracket or similar, all help would be much appreciated, thanks.
#2 Posted : Saturday, 28 April 2007 9:14:18 PM(UTC)
You'll have to make up a bracket. I'd use a SD508 or similar compressor, and i've seen them mounted above the power steering pump (driver's side) and also a combination alternator/compressor bracket over under the throttle body duct. Whatever you do looks
