BAG308 Offline
#1 Posted : Saturday, 21 October 2006 3:45:54 AM(UTC)
BAG308
gday
i have got a 9 inch out of a XB falcon to fit into my hx ute. i want to keep the original brakes on the diff because it is a disk brake diff. is it possible to change the stud pattern to holden or not? if so who could do it?
scott
Ark it or Park it !!
ozchevy Offline
#2 Posted : Saturday, 21 October 2006 4:07:31 AM(UTC)
ozchevy
Yes it is possible,
The axle will need to be set up in a Indexing Head on a Universal Milling machine, the PCD will be calculated and the 5 holes set on the index plate. Where are you located, if your anywhere near Sydneys Western suburbs, then I can do
peter_flane Offline
#3 Posted : Saturday, 21 October 2006 7:14:27 AM(UTC)
peter_flane
Just be warned that it is not legal to change stud pattern on an axle. If you have a catastrophic failure due to the restudding, your insurance won't touch you, and you may get yourself or someone else hurt.
This page was generated in 0.100 seconds.
