#1 Posted : Sunday, 22 October 2006 3:11:49 AM(UTC)
hi i have an xe falcon ute and just brought a xe falcon station wagon and it has a EFI motor in it, im looking at doing a swap over to the ute will the EFI motor fit stright in??
Fred Offline
#2 Posted : Sunday, 22 October 2006 7:28:56 PM(UTC)
Fred
I can't see why now, just have to use all the EFI accessories are you using the same gearbox thats in the ute.
#3 Posted : Monday, 23 October 2006 11:17:26 PM(UTC)
In a way you are lucky using the Wagon setup as the wagon still uses a steel (as opposed to the sedans plastic) fuel tank.
The wagons have their high pressure fuel pump in front of the tank not in the tank. You may have to add a facet type elecric pum
#4 Posted : Tuesday, 24 October 2006 9:21:21 PM(UTC)
well i have throught it oput now and its to much trouble to take the whole wiring harness out of the station wagon and put it in the ute, so im just going to put the ute mainafolds onto the new engine hopefuly it all fits and works well.
anything i shoul
#5 Posted : Wednesday, 25 October 2006 2:50:31 AM(UTC)
I haven't done the ford conversion, only the holden, but they are basically the same setup.
You really only need the engine harness, the wires that go to the injectors, computer, fuel pump etc.
You will need to plumb in a return fuel line to the tank, i
#6 Posted : Wednesday, 25 October 2006 9:10:43 PM(UTC)
Originally posted by bundyman
Its to much trouble to take the whole wiring harness out of the station wagon and put it
This page was generated in 0.083 seconds.
