Hi, I was wondering if the bore size of a motor affects it's actual capacity. For example what would the capacity be of a 308 with 030 block or one with a 060 block be? Thanks
Work it out: Cubic capacity = pi x bore/2 x bore/2 x stroke x 8 (all in inches). 308's have a 4" bore and 3.062" stroke. For a bigger bore like 30 thou use 4.030". Edited by user Wednesday, 25 October 2006 5:31:48 PM(UTC)
| Reason: Not specified |
Joined: 3/03/2005(UTC) Posts: 287 ![Australia Australia]()
How dose 312.461 cubic inches sound!
An easier formula is, Bore dia X Bore dia X .7854 X stroke length X number of cylinders
