#1 Posted : Thursday, 26 October 2006 6:16:43 AM(UTC)
Just Bought a pranged VS stato and are in the process of fitting interior/electrics into my VR ute (5.0L auto)
Two problems I am having:
Fitted power window switch wiring and switch from stato and plugged them into the existing wiring in the ute and fitted relays from the stato engine bay relay/fuse box to ute window relays as i could not find window relays in stato and I can only get the drivers regulator to go down and not up - am I using the wrong relays or is there another problem
What do i have to do get fuel usage operational on stato dash as it is fully operational except for this - is there a flow meter for fuel or is it calculated from the ECU
#2 Posted : Thursday, 26 October 2006 6:56:48 AM(UTC)
Fuel usage is the yellow/black stripe wire in the dash harness plug at the PCM. It will come out of the PCM harness, but won't have a matching wire in the dash harness. Add this wire, and it goes in the extra plug under the cluster.
As far as the win
#3 Posted : Thursday, 26 October 2006 7:22:50 AM(UTC)
Thanks heaps for the help -
I have used stato instument/dash harness with the ute main harness, will i have to run the wire to the dash harness conector under the dash from the PCM or should it be already there? Should that wire be in the stato instru
#4 Posted : Thursday, 26 October 2006 7:43:11 AM(UTC)
Sorry I miss read your reply on the window relay - just checked and I have only fitted a 4 pin relay - I will geat a 5 and try it
I can see the yellow black wire in the instrument (stato harness) but can not see were it runs in the big instrument harn
#5 Posted : Thursday, 26 October 2006 7:50:04 AM(UTC)
Yes, join it up from the small instrument plug, across the car, to the PCM plug.
The 4 & 5 pin mini-relays are colour coded. From memory the blue striped ones are 4 pin, and yellow are 5 pin.
#6 Posted : Thursday, 26 October 2006 8:12:19 AM(UTC)
Cool thanks heaps for the help
#7 Posted : Sunday, 29 October 2006 4:55:22 AM(UTC)
The PCM wire is the yellow wire with black stipe and brown trace not just yellow wire with the brown stripe - that one does not work
This page was generated in 0.113 seconds.
