Rimmo Offline
#1 Posted : Monday, 30 October 2006 12:19:08 PM(UTC)
Rimmo
can somebody talk me through measuring bearing crush when assembling a motor/what measurement it should be and how to fix it if it's out?
#2 Posted : Monday, 30 October 2006 5:52:15 PM(UTC)
Buy some plastiguage. You put a piece between the bearing and the crank and torque up the cap. When you remove it compare the width it has squashed to, to a chart. This tells you the bearing clerance. Fix it? A crank grind and new bearings.
Rimmo Offline
#3 Posted : Monday, 30 October 2006 10:13:16 PM(UTC)
Rimmo
so it's as simple as measuring bearing clearance? I vaguely remember reading an old article by Bob Kotmel about checking bearing crush as it was supposed to stop the bearing shells from spining. This was seperate to checking your clearances.
#4 Posted : Tuesday, 31 October 2006 4:31:08 AM(UTC)
Hi guys
Aren't we talking about 2 different things here...bearing crush and bearing clearance, with Plastigage used to check clearance.
I thought crush would be checked by snapping the big end shells into the rod and cap,place together and torque up the
Rimmo Offline
#5 Posted : Tuesday, 31 October 2006 8:19:50 AM(UTC)
Rimmo
Thats the one I was after, so if the measurement is less than 0.1mm there's not enough crush right? What's the measurement for the mains?
madjack Offline
#6 Posted : Tuesday, 31 October 2006 10:56:05 AM(UTC)
madjack
Yes, correct, the smaller the gap the less the crush.My info says expect to see 0.1mm as the desirable lower limit, and 0.025mm as unacceptable.
And for the mains 0.075 to 0.125mm.
If you can get one,grab a copy of How to Blueprint & Build for High Perf
#7 Posted : Tuesday, 31 October 2006 5:30:10 PM(UTC)
Correct. I misread your original post.
Rimmo Offline
#8 Posted : Wednesday, 1 November 2006 12:42:10 AM(UTC)
Rimmo
Thanks guys you've been a big help.
Guest (7)
