#1 Posted : Saturday, 4 November 2006 3:00:01 AM(UTC)
i AM LOOKING AT BUYING AN OLD 350 CHEV 010 SHORT MOTOR TO DO UP,
WHATS THE DIFFERENCE BETWEEN A 2 BOLT AND A 4 BOLT ?? (2 BOLTS YEA I KNOW )
DOES ANYONE KNOW WHERE I CAN GET THE CORRECT INFORMATION ON THE BEST OPTIONS TO REBUILD AND DO IT UP, IE CRANKS AND CAM TYPES, MAX. BORE ETC
AS YOU CAN SEE I'M A NOVICE WITH CHEVS,
THANKS
MARK
Sandman Offline
#2 Posted : Saturday, 4 November 2006 4:19:14 AM(UTC)
Sandman
If it's an 010 block, then it should be a 4 bolt main.
Chev blocks are fairly hardy tho and unless your planning on squeezing a lot of rpm and HP out, then 2 bolt blocks with cast cranks are fine.
What do you want to build it up to suit?? Street? What
#3 Posted : Saturday, 4 November 2006 4:56:02 AM(UTC)
yeh im thinking of putting it in a hz but im not sure yet, but probably a turbo 400 ?? i want it registered and i also want run it at the drags, to start with anyway.
i dont want to go too overboard with the rebuild, but i want it to be grunty
#4 Posted : Saturday, 4 November 2006 6:44:05 AM(UTC)
Not all 010 blocks are 4 bolt.
Four bolt is a bit of over kill for a street car but if you intend to rev the day lights out of it or race then go the four bolt.
Carefull fitting it to a HZ. You will probally have to run straight gas to meet EPA. The
#5 Posted : Saturday, 4 November 2006 7:01:27 PM(UTC)
SO IF A HZ MAY BE A BIT OF A PROBLEM TO REG, WHAT ELSE COULD I PUT THIS 350 INTO THAT WOULD MAKE IT ALL A BIT EASIER. AND STRAIGHT FORWARD
