tanart Offline
#1 Posted : Wednesday, 2 May 2007 11:20:44 PM(UTC)
tanart
I've just bought myself a new HEI for my 350 chev and want to know what gaps i need set the spark plug gaps to. Also is it recommended that i change the plugs to suit electronic ignition as well? The plugs are new champions.
dca1042 Offline
#2 Posted : Thursday, 3 May 2007 6:12:34 AM(UTC)
dca1042
i normally run 1.35mm to 1.5mm, works a treat.make sure you have 12volts running to your hei from ignition,or it will not run properly.cheers dave.
tanart Offline
#3 Posted : Thursday, 3 May 2007 8:40:39 AM(UTC)
tanart
thanks. I'll try it on the weekend.
