#1 Posted : Sunday, 12 November 2006 6:04:02 AM(UTC)
i have recently purchased a hj panel van with a 350 chev on duel fuel. it has been sitting in the sellers garage for a couple of years and i was wondering if there is any pre-cautions i should take before cranking it over? should i change the engine oil, trans oil and rad fluid before i give it a bit of a run?
Also, it needs a new starter motor and ignition barrel hooked up, my question is how hard is it to replace myself, how do i it (what tools do i need) and how long will it take?
Sorry for all the questions guys but i really need some answers
tom
#2 Posted : Sunday, 12 November 2006 6:52:12 AM(UTC)
Before you crank it over, take the heads off & check the combustion chambers & the cylinders. I would replace the oil, coil, leads, spark plugs, thermostat etc...
#3 Posted : Sunday, 12 November 2006 8:34:39 PM(UTC)
I'd check everything like plugs etc.
Change the oil and filter.
Drain the radiator flush the cooling system and put a new thermostat in.
Taking the heads off is a very cautious thing to do. Not silly by any means, but time consuming and maybe not neces
#4 Posted : Monday, 13 November 2006 4:43:12 AM(UTC)
thanks heaps for all the info guy's and yes i did mean replace the ignition barrel as the one thats in already can be turned without using the key.
Would it be a much wiser idea to call out a mechanic to come and service and tune up everything plus h
