#1 Posted : Monday, 13 November 2006 2:58:20 AM(UTC)
gday
i am rebuilding my front calipers on my hz ute (girlock) and was woundering if there is a special grease you use to grezze up the pistion to fit it into the caliper housing?
any healp would be much appreciated
scott
Munromad2004 Offline
#2 Posted : Monday, 13 November 2006 3:44:43 AM(UTC)
Munromad2004
Hopefully I can help you as I just went and had a quick read through a couple of manuals covering this topic.
The HZ manual says to lubricate the entire outer of the piston (and the piston boot) with rubber grease.
The piston seal is to be dipped in
#3 Posted : Monday, 13 November 2006 8:23:51 AM(UTC)
cheers thanks for your help
