#1 Posted : Monday, 13 November 2006 11:32:14 PM(UTC)
what would bolt straight into a uc sunbird???
when i die bury me face down so anyone who doesnt like me can kiss my A**...
#2 Posted : Tuesday, 14 November 2006 2:13:54 AM(UTC)
Hi goingcrazy.
If your UC Sunbird has a Starfire 4, then a Holden 6 will bolt straight in to the original mounts. If it has an Opel motor, the front cross-member needs to be changed to fit the 6. Anything else is a lot more work.
Dr Terry.
jabba Offline
#3 Posted : Tuesday, 14 November 2006 7:22:31 AM(UTC)
jabba
And if it has the starfire 4 - DON'T turbocharge it, or rev it, or even look at it wrong (in my experience).
The most entertaining problem I tried to diagnose on my old one was when I fitted the distributor cap 180 degrees out. Entirely possible and d
#4 Posted : Tuesday, 14 November 2006 11:20:55 PM(UTC)
how can you tell the difference between the starfire and opel engines
#5 Posted : Wednesday, 15 November 2006 1:01:26 AM(UTC)
Hi goingcrazy.
The Starfire 4 is just a Holden 6 with 2 cylinders missing, so the carby is on the passenger's side & the dissy is on the driver's side & the rocker cover is the same style as a Holden 6, but shorter.
An Opel 1900 is a larger, heavier
