#1 Posted : Saturday, 5 May 2007 12:02:21 AM(UTC)
Hey guys i was just wondering if there are different size springs for the 6cyl and the v8's ?
The reason i ask is that when i bought my coupe it came with an extra set of front and rear springs and the clevo :)
The extra set of rear spring are the same as the original ones on it.It had a 6cyl in it when it was last running but at some stage it had a v8 in it !
Any help much appreciated .
Mal
Paul351xb Offline
#2 Posted : Saturday, 5 May 2007 2:00:06 AM(UTC)
Paul351xb
V8 front springs are slightly thicker and are stiffer. As for the rear springs, some V8 rear springs had an extra leaf in them but not all. I'm still running the 6 cyl rear leafs in my coupe. Haven't had any problems.
#3 Posted : Saturday, 5 May 2007 3:28:08 AM(UTC)
Thanks Paul , you are a wealth of knowledge :)
Mal.
Paul351xb Offline
#4 Posted : Sunday, 6 May 2007 4:07:00 AM(UTC)
Paul351xb
No probs mate. Did you track down your GT bonnet yet?
You can always make a GT grille out of a standard grille.
Shane at www.xbfordfalconshop.com has reproduction grille rings. Just cut the hole and glue the rings in. Original GT grilles were made fr
#5 Posted : Monday, 7 May 2007 6:33:20 AM(UTC)
Thats what i was thinking of doing but i havent really looked into it yet , as for the bonnet im still looking but its not important atm. Im still busy in the back end of the car removing rust and welding in the new replacement panels only the bottom r/h
