#1 Posted : Saturday, 5 May 2007 1:12:42 AM(UTC)
Is there anything to be aware of when changing cams over in a 186 and can I do it with the motor still in the car
?? Ive just picked up a 202 with a YT head and some other goodies on it so was going to swap some things over, its supposed to have a mild cam in it so was going to swap them if possible.
Also anyone know of a good head specialist in Perth that can advise and service this head for me?
Later!
 1 user thanked Guest for this useful post.
Tony Wythes on 12/03/2019(UTC)
peter_flane Offline
#2 Posted : Saturday, 5 May 2007 5:13:20 AM(UTC)
peter_flane
I just recently changed cam in my 202. I did it in the car. Remove belts, pulleys, harmonic balancer, timing cover. Remove fuel pump, distributor and oil pump. Remove rocker gear, pushrods and lifters. Then remove two screws on cam plate. Draw out cam, pr
This page was generated in 0.093 seconds.
