#1 Posted : Friday, 17 November 2006 6:00:43 AM(UTC)
i've bought a HQ in bits, and its been a while since i've seen one,
can anyone tell me where the vents cables are mounted and routed, also the bonnet cable.
i've also got a problem i think with the front windows tilting forward when winding them up. new bailey channels have been fitted but the rear of the new bailey channel on the drivers door is just hanging down twisted, theirs a hole on the door right where the channel sits, is there anything that helps the window or stops the channel twisting ?
mark
#2 Posted : Friday, 17 November 2006 6:23:00 AM(UTC)
Hi Mark,
I'm sure I have a diagram detailing the Vent cable routing. Send me an E-mail and I'll send it to you (click on my name to send me an E-mail).
The bonnet cable is clipped onto the body along the top of the driver's side guard. You may be ab
Edited by user Friday, 17 November 2006 6:23:34 AM(UTC)  | Reason: Not specified
#3 Posted : Sunday, 19 November 2006 4:48:41 PM(UTC)
thanks dave for replying,
got a few projects on your website !
i've seen where the bonnet cable goes, and i've worked out where the vent cables go as well, the drivers one curls round the back of the dash, and i assume they have a nut and bolt thro
#4 Posted : Monday, 20 November 2006 12:49:13 PM(UTC)
Hi Mark,
The easy question there is the :HS rear lights wiring...it goes across the car behind (in front of?) the number plate.
I'll have to look at my wiper motor and heater tap tomorrow in the light.
There is a solid channel that the Bailey Cha
#5 Posted : Monday, 20 November 2006 9:44:56 PM(UTC)
Hi Guys.
HQs do not have a heater tap unless it has Frigidaire Factory Air & then they are vacuum operated, not cable.
The hot/cold cable operates the lever on the lower left of the heater box.
In the door, you are missing the small vertical chan
#6 Posted : Tuesday, 21 November 2006 12:46:27 PM(UTC)
Ah, yes, Terry. I'll have trouble finding mine, won't I? Just shows how long since I looked at the heater in the Qute :-)
Sorry, Mark, forgot all about looking at my wiper motor this arvo. Will try to remember not to forget tomorrow...
Cheers...Dave
