Blue ballz Offline
#1 Posted : Friday, 17 November 2006 7:23:52 AM(UTC)
Blue ballz
Want to see if it is possible to convert a standard vs s2 ute dash to one from a berlina or calais to include a tacho in the panel
#2 Posted : Friday, 17 November 2006 8:16:49 PM(UTC)
You can insert a level 2 tacho dash from any VS executive etc. The calais dash will work but needs mods for the trip computer.
Warren
Blue ballz Offline
#3 Posted : Friday, 8 December 2006 8:06:51 AM(UTC)
Blue ballz
with this i want to try and upgrade the instrument cluster to include the trip computer in to the hole ion my dash. In this I want to upgrade to combination switches for the wipers and possible insatll the combination switch to include the cruise control
#4 Posted : Friday, 8 December 2006 6:37:41 PM(UTC)
As Warren has noted, there's a lot of extra work to put a trip computer cluster in. There are 2 additional plugs in the loom - one for the switches, and one for the cluster - that you need to splice in to make it work.
It's not as easy as swapping the
Blue ballz Offline
#5 Posted : Saturday, 9 December 2006 11:57:04 PM(UTC)
Blue ballz
is it possible to install cruise control in a manual ute???
#6 Posted : Sunday, 10 December 2006 5:36:14 AM(UTC)
Yes it is. You simply fit another cutoff switch like the brake one, to the clutch pedal, and wire in in series with the brake cutoff.
A lot of people aim to achieve no
Blue ballz Offline
#7 Posted : Sunday, 10 December 2006 9:05:49 AM(UTC)
Blue ballz
when your talking underbody loom and and dash loom what in particular are you talking about? In the dash loom are you talking about the instrument cluster and the surround or am i singing off a different sheet off music?
#8 Posted : Sunday, 10 December 2006 9:19:12 AM(UTC)
Dash loom does the instruments, headlight switch, speed alert, hazard switch, glovebox light - basically everything attached to the top half of the dash.
The main body loom does the aircon, radio and everything below that level (incl central lock, unde
Blue ballz Offline
#9 Posted : Sunday, 10 December 2006 6:28:50 PM(UTC)
Blue ballz
so to really do this easily is to take the wreck as you say and take mine out and put that one in. Calais have the climate control how would that effect the task?
#10 Posted : Sunday, 10 December 2006 7:28:30 PM(UTC)
That's basically the best way.
There's already some good threads dealing with climate control and the loom swap:
http://www.fastlane.com....9116&SearchTerms=climate
http://www.fastlane.com....ms/topic.asp?TOPIC_ID=90
Blue ballz Offline
#11 Posted : Sunday, 10 December 2006 11:05:06 PM(UTC)
Blue ballz
with all these things is the any thing special required to get them off and back in? Is it just undo and and re-install no tuning from an auto electrician as such. What are you calling a bcm?
it easier to do nothing than something
This page was generated in 0.065 seconds.
